Sets STP bridge priority values.
| stpd | STP domain/STP global configuration. |
| stpd_name | STP domain name on the switch. |
| priority-mode | Control allowable bridge priority values. |
| dot1d | Allow any bridge priority value. Valid values are 0–65,535 (in increments of 1), with 0 indicating high priority and 65,535 low priority. |
| dot1t | Allow bridge priority in steps of 4,096. This option is the default bridge priority mode. Valid values are 0–61,440 (in increments of 4,096), with 0 indicating high priority and 61,440 low priority. Values are automatically rounded up or down depending on the dot1t value to which the entered value is closest. |
dot1t option is configured by default for operation mode dot1w and MSTP.
The following example configures the priority-mode as dot1d:
configure stpd s1 priority-mode dot1d
This command was first available in ExtremeXOS 22.1.
